Hello,
We love our SQ-6 and the SQ4You app. However, we pretty regularly have 8-10 musicians on stage with IEM mixes. Would it be possible for Allen & Heath to increase the number of instances of SQ4You that can run simultaneously? Perhaps you can even allow the user to trade 1 of the 2 SQ-MixPad instances for more SQ4You instances. 10 instances of SQ4You and 1 instance of SQ-MixPad would be great for us. Maybe since there are 12 auxes 12 instances of SQ4You plus SQ-MixPad would make sense.
Thank you,
Joshua
I assume it’s the meter data that is the bulk of the bandwidth that forces this limitation?
If so, maybe they could limit the number of clients that receive this data and then increase the number of possible clients as data demand/service will be lower…
I had the same thought about the meter data using the bulk of the bandwidth. Perhaps an option could be added to eliminate or reduce the metering data to some or all of the clients in exchange for allowing more clients.
