Indipendent controls on mixpad... it is possibile?
Hi! Yesterday i had the first live show with my new SQ6. A serious problem i’ve encountered is the impossibility to separate functions on the console and mixpad to do indipendent works ( Console FOH - Mixpad AUXES). Every time the FOH Engineer change layer, Select Busses, Matrix, etc. the Mixpad follow the Console changing the scenario for the STAGE Engineer. Is it possible to do separate controls? I’ve Tried to block different user options FROM the Console to ipad But it seems DON’T work. Any help is much apreciated. Thanks.
Switch off Follow SQ Channel & Mix Select options in Mixpad setup.
Thank you very much! ??
