Individual L,R assignment of StBus by SigGen
I want to turn SigGen on and off for each L.ch and R.ch of the output bus individually.
This is possible with dLive, but not with Avantis or AvantisSolo, even with the current latest version.
I always run into this wall when using an iPad to check output.
It’s not ideal, obviously, but the best thing to do before/if it gets added, would be to sac off an input channel, change the input of that channel to be the SigGen, assign to the appropriate outs/groups/auxes and pan accordingly when needed.
How do you guys do the “StAux on IEM L/R feed” check and the “INPUT to StMatrix” check?
I’m always having trouble with Avantis SigGen because even though it is equipped with it, it outputs at the same time.
