Input comp and delay not evident on a post fade mix.
I am sending multiple inputs to a post fade mix (as an eq group) and sending that mix straight out of the matrix. But the input channel comp and delay etc does not seem to affect the send to the mix. It does however if you route inputs straight out of L/R. Is there a way to change the insert point of the input dynamics etc in order to make sure they’re carried to the mix?
This is how I always work on corporate shows, I never use the L/R buss.
Page 37 in the reference guide covers how to change this. Configuring the bus as an actual group would also achieve this if you don’t need the variable send level, this is on page 64.
https://www.allen-heath.com/media/SQ_ReferenceGuide_V1_4_0.pdf
Chris
Thats the Badger!
Many thanks, thats perfect.
