Hey there! Not sure if I’m missing something… when I delay one of my Input Channels (let’s say an audio-input from a video feed) this only affects the MAIN-Out… not Monitor-Mix-Outputs!?
With my Qu-16 I realized 2 Delaylines with Post-Fader Mixes. The Input-Delay of my Video Feed does just affect the Front PA and not the delaylines!
I’ve got the latest firmware but I can’t tell you If it’s a bug or if I’m just expecting something that doesn’t have to be!? ;D
In my case… there was a Video Feed that was delayed on the screens. So I wanted to adjust the audio-delay matching the video signal. Unfortunately I had to add the same delay that I used on the Main Speaker as well to the MIX1 and MIX2 out… but then for the Speech it was adjusted wrong… so I ended up just using the Front PA for the video feed with the delay compensated at the Input-Channel and used the delaylines just in connection with the MC.
Your thoughts?
