Input level metering issue
I have a suggestion for a future update:
a clipping preamp won’t show up on the meters anymore when the signal also is attenuated by digital trim.
As an example you can gain the preamp all the way up to 60dB and trim the signal 24dB afterwards on a mic input. Even when you select “input meter source Post Preamp” you will not get a visual representation of the signal overloading.
Maybe it is not possible (with firmware/software update).
