Input Library Names Recallable
I don’t think this is something I’m just missing…
We are using this in a church where our band is different every week as we rotate through different combinations of musicians and vocalists. We have always used an “input library” in our 10 years on Yamaha digital. The library on the dLIVE is almost the same thing but it would be super helpful to have the option to also save/recall the NAME onto an input as well as the channel and preamp settings.
It would save a little time and confusion for us weekly.
save this to a scene
actually save a scene and only recall the needed information
or totally different
repatch your inputs to the named and processed channels
or
reconfigure your surface with the needed channels
keep the DCA Spill in mind that helps a lot
you can apply strips to the to the surface by select them in the DCA routing :slight_smile:
@Steffen those are certainly valid ways to work around the challenge I face…
but I’d rather then just tick box that allows channel names to be recallable. THAT would be far quicker and simpler… and I don’t understand why it wouldn’t be desired by many.
after rethinking a little…
I agree it wolud be helpful, didn’t get the point in the first round :frowning:
one step further…
a patch library feature, aside from the scenes
store a patch to a memory would make it easier to overview the patch changes
and it helps to keep the processing in place
I know this would work with scenes, but to have it extra in a library would make it easier
