Input meter on ip6/ip1 source select.
When using the ip6/1, source select scrolling shows you the input meter of the playing channel. I work a venue with 5 sources and when the place is packed and things are stressful it’s not easy to communicate which source is active. Having the input meter follow the highlighted source would help a lot for identifying which source should be active.
