If I have an input into Channel 1 and have the HPF and PEQ set, is there any way to get the same CH1 signal without the HPF and PEG settings available to send to a ‘Mix’ channel…I won’t say why I want to do this though!
“Choose the global Channel Source for the selected
mix. This is the point in the channel signal path that
feeds the mix. This affects all sends to the mix.
Choose Post-Preamp if you want the sources to
the mix not affected by any channel processing.”
I will often use the “Pre-EQ” setting for monitor sends. I still want the HPF in there.
The system is a pair of active RCF TT25A ii and single JBL VRX918SP.
I know the system is ‘undersubed’ so to speak but it’s for pub rock in small/medium sized rooms (100 people). I rely a good bit on the natural kick drum and bass backline and don’t run very bass heavy mix.
The RCF’s have an inbuilt 100Hz HPF.
The Sub has either 80Hz or 120Hz LPF. I want to run the sub at 80Hz and get the RCF’s down more into that range by not using the onboard HPF and using the QU-SB HPF settings on each relevant input. I’m basically only using the sub to take some of the load off the tops to maintain a bit of headroom (the RCF tops go very hard if required).
I know the QU-SB isn’t a loudspeaker processor though…just trying things out…
What Bob’s suggesting, is that you patch, for example Kick to both channel 1 & 2 (with an analogue splitter at the desk, or digitally if you’re using the dSnake), allowing you to eq each one differently. Would give you more options but eats up extra channels.
