Hello every one,
My QU16 is set up in my computer room, but it’s rear panel pre amp inputs and outputs are unaccessible.
I have an AR84 mounted in my audio rack, to plug in instruments located in my control room.
I use an AB168 for my “dead” tracking room.
I want more inputs and outputs for my “live” tracking room, but I was told another AB168 would not work with my system.
Can anyone help me get three rooms rigged with inputs and outputs?
I run 2 of the AB168’s on my Qu-16 and Qu-24, but I don’t believe you can run 3 expander boxes (by adding an AR84).
I’ve never tried that, but according to the manual, you can’t.
I think the best option would be to make (or buy) an analog XLR patch panel (or short snake box) to connect to your QU16. That way even if the rear of the console isn’t easily accessible, you can put the patch panel/snake box where it is more accessible.
You might want to look at Dante AVIO devices as they are perfect for this and not too expensive. They would take analog outputs from your AB/AR box and route them over ethernet to the different rooms, where you would convert them back to analog in those rooms using another AVIO device.
