I´ve been trying today after updating the mixer to V1.51 to Insert one of the FX racks (Transient, Multiband C, and Subharmonic) direct into a channel, but I couldn’t and if my memory is not pretty rusted I´m quite sure it was possible before??? probably my memory is not working,…
any one?
See section 5.2 on page 19 of the manual. Essentially you need to go to the back panel of the fx and set it to insert then choose the required input Channel.
or alternatively, go to the FX tab on the processing of the channel, then under “send” chose rackFX and select the appropriate FX unit.
Yes! That’s exactly how I remembered! Strange I didn’t find it last time… I’ll take a look again asap!
Ok! so I´ve found the trick, in the rear panel of the FX there is a little button where you can select if it is a SND-RTN or an Insert =) problem solved.
Thanks everyone!
