A new sound engineer should use our GLD has asked me to insert a outboard compressor on the fader master LR. Is possible to do that on the surface? or I’ll have to pull a cable from FOH to analog speakers? I wish possible.
GLD-80
2412
84
GLD-80
2412
84
You can do this on the processing screen: select Main L-R, touch the INSERT tab, and set up the send / return on the surface XLRs IN/OUT x2, and press apply. the outboard compressor can be bypassed if you need to on the INSERT section of the LR mix on screen.
please do not adjust your set; normal service will be resumed as soon as possible!
Thank you, very nice. Tomorrow I’ll try. I guess the return channel gains are useless, the inputs aren’t still mic preamps. Is that so?
GLD-80
2412
84
The ‘return’ path is not an input channel - the XLR socket simply gets used as an insert return via patch-bay to the main L-R. no preamp gain controls!.
you do have a widget to change operating level between +4dBU and -10dBV.
It worked perfect. But is it normal a hiss noise when I set the mix buss insert? I experienced this, and not the fault of the Outboard, I tried without plugging. What is your experience?
Regards!
GLD-80
2412
84
