Insert point bypass in scene recall
Does anyone know which recall filter affects the insert point of each of the channels/groups?
Basically I want to set up a scene that will bypass all inserts at once in case of a crash on waves. I know there isn’t one specific filter that controls the bypass but one of the filters must be responsible for the state of the inserts when a scene is saved.
My other thought on a workaround would be to use the patch filter and remove the patching to the card?
Any input would be appreciated
Cheers
Neil
Neil,
Not exactly. I wanted to do the same thing and found that the Input / FX tab “Processing” button the input side will affect the insert bypassing. Unfortunately it will also recall all other processing. I’m going to post a feature request for this. Maybe you can +1 it. :slight_smile:
Neil,
My feature request is at: Recall Filter for Inserts
Hey, just commented on your post before seeing your reply here. I posted my original post before I actually received my desk and then figured it out.
But totally agree a recall filter or at least an option to use a soft key to bypass all inserts or something would really make for a much safer mixing experience
Neil
