Is it possible to set the insert point on channels/busses? If so, how do you do it?
The insert points in the channels are fixed in core architecture, so it’s not possible to move them around.
If you’re wanting to use inserts later in the signal path, a workaround is to use either direct outputs or groups.
The insert point is directly after the gain and pre everything else?
The SQ input channel insert point is post-gate, pre-EQ.
The mix/output channel insert point is pre-GEQ.
You can see both of these here - https://www.allen-heath.com/media/SQ_ReferenceGuide_V1_5_0.pdf#page=109&zoom=auto,-295,1
Maybe it is possible to choose the insert point position between pre-gate or post-gate ? Only this would be awesome already
