Hey,
It would be very helpful and timesaving if the insert return would follow the insert send. In most cases you’ll return the same way you sent the insert.
For example, I make an insert through ‘local socket output 1’, the return will also automatically assign ‘local socket input 1’.
Or have it in an option, ‘return follows send’.
Thank you. Kind regards, Bram
