Integrate A&H Midi App translation functionality into CQ18T mixer for live scenarios
As you noted, you need some sort of “midi bridge” between your console and the mid devices to translate the data between the two different protocols/systems.
There are potentially many different options, but three stick out in my mind.
  1. Use the third party app “Mixing Station”. This is still a software solution (like the A&H Midi App) that has to be running on a hardware device, but that hardware device can be a computer, a tablet, or even a mobile phone. You just need to be able to plug in the Midi device into it via USB. I have used this setup to add a motorized Midi fader controller running off an Android tablet very successfully. The advantage to this solution is that it is extremely inexpensive (just the cost of the MS license) to implement, but the disadvantage is the fact that it is a software solution that must be “running” for the Midi devices to communicate with the console.
  2. Bome Box is a hardware solution that you can purchase that acts as this “translator”. Once it is properly programmed, it basically is a “plug and play” device that does not require any attention. Just plug it into the console and the Midi devices into it and it should just work. The advantage here is the “plug and play” simplicity of the system, but the disadvantage is the cost of the Bome Box.
  3. A member of this forum @frenchie has been developing his own hardware solution. He has been documenting his process and I believe he has released his programming if you wanted to try to duplicate it. You can get more information about it here. DIY external midi controller for the CQ
