IO Card Slot Label
Am I missing a setting to label the IO Card slots internally? If I’m not, could that be a feature that’s added? Even if it doesn’t report the name from the card itself, if I could do it manually…
Great feature request. We have a FOH/MONITOR setup with multiple cards in use over 2 consoles and 2 mixracks. This would make things far simpler in the IO tabs for sure.
Related is labels for the channels of the I/O card. For example, you always have external hardware hooked up on the same channels to use as hardware inserts. Would sure be nice to pick a named port instead of just a number for the send/return pair.
