Has anyone has issue where IO Patch setting is frozen after we made modification using SQ MixPad in PC? Steps:-
- Save a show in the thumbdrive
- Copy the files from the thumbdrive into PC
- Load the show in PC’s SQ Mixpad
- Make modification to the IO Patch using the SQ Mixpad
- Save the scene and show with the SQ MixPad in PC
- Copy the files from the PC to the thumbdrive, overwriting the thumbdrive configuration
- load the show from thumbdrive in the SQQ7 console
- Go into IO Patch and try to scroll to look at all the inputs and outputs and its patching, but it freezes on the console. You can tap on different tabs and it will load accordingly, it just does not allow you to scroll through the full list of inputs (48 channels down) and outputs (128 channels to the right) to view and make modification.
The only way to modify IO Patch on the SQ7 console is to use the SQ Mixpad in the tablet and sync with the SQ7 console, then make modification through the SQ Mixpad.
Is this a bug? Is there a way to “unfreeze” the patching list?
