ipad and ios10 stopped DHCP with router without internet
Up till now all has worked fine connecting to the router, but since updating to ios10 on an ipad 3 the connection to the router via DHCP didn’t work, the problem was the wifi connection wanted to see an internet connection. usually it would give the option to use without internet and just use wifi OK, but this option didn’t become available.
I know this is a router issue and not the desk but i wanted to post here to see if anyone has experienced this and if there is a guaranteed way to connect? as i did eventually get it to work using static IP i didn’t really know what i was doing and it was more luck than judgement that i got it to work just minutes before a gig. but it still said “security issue” next to the wifi connection, but at least it worked phew
Just want to make sure i don’t hit this problem again, especially as we have 2 QU32 desks with the same ASUS DSL N55U routers (Which has great range by the way)
Thanks for any help or suggested settings
Chris
the router should deliver ip adress to the iOS devices without the internet
you are in a local network and this should work independent from internet access
the standard gateway is the way to the internet, normally the router
use a static adresses for the consoles anyway
set the range for dhcp adresses different than the consoles adresses
name them different to identify them in the network
iOS is just broken with wifi.
The connection is are, but there is no icon. And it doesn’t think it’s made for ages…
On iOS, make sure that WiFi Assist is turned off. I believe this is only for devices with a cellular connection, but I could be wrong.
