Ipad app locked login
I’m not sure of it’s already mentioned somewhere.
What I would like to see is that the Ipad apps stay logged in for as long as the Ipad is active. Even when switching between different apps.
For example: when using a patchlist in an app like Numbers it would be useful to continually be able to switch between these apps without the need of logging in, time after time. Now, after switching to a different app for a short time you will have to log in the GLD-app again.
Another example: as a musician I use OneMix next to DD GigBook to read my setlist and lyrics. If I want to make a slight change to my personal monitoring settings and return to OneMix I first have to log in again.
I understand the safety reasons but I’m sure that logging in with the Guest account could have this function?
Kees
I think there should be the option of setting this feature with any account. It’s a royal pain to have to log in every time I close the cover for longer than a minute. It should remember the last used board and login information for the last used account. As long as it’s a user selectable feature, I don’t see a problem.
