This is a really “out there” suggestion…
The Qu-You app is limited to 8+1 faders (which is a limitation I can work with - particularly with multiple layers)
What I found using it as a the interface to a mixer was that the touch screen needs a little too much visual confirmation.
I’ll get used to it, and it’s not a killer… But…
What would be awesome is an iPad case…
with both 30 pin and lightning cables to plug into the iPad (or maybe bluetooth?)
with a “charge through” port (likely not needed if bluetooth, could still be useful*)
with a strap handle and a stand on the rear (so it can be handheld easily, or propped up)
with a “side pod” of 9 Qu-You style “wheels” OR 9 faders (probably short)
The wheels would control the faders on screen, but provide no feedback on level directly.
The fader option would require motorised faders which jumped to the relevant position on each layer change and or swipe along the screen, that’s probably too much power requirement…
Additionally a “layer up” and “layer down” button set (or wheel?) would be useful…
Having thought about it for a couple of weeks, I still managed to come up with the wheels idea as I was typing it out.
Basically I’d like a tactile control surface on the iPad, it doesn’t need to be big or clever (the iPad is that), but something relatively simple should be doable.
Anyone done any iOS hardware integration?
For instance if it had microUSB charging itself it could pass that on as USB power to link to any iPad
The following is a reply from A&H regarding using the Qu-pad app hard-wired to the desk, but it probably applies here:
Can anyone tell me if it’s possible to connect an iPad running the Qu-pad app directly to the network port on the Qu-16?
An iPad running the Qu-Pad app is only designed to operate wirelessly,
Connecting a USB - Ethernet lead is not supported, there are no plans to support this at present.
Yes, I wouldn’t do anything differently.
This would be a case for the iPad which provided some physical control over the app - the app still has the only (wireless) connection to the mixer.
Out of interest I’ve have thought that if the iPad was connected via a Proprietary → ethernet cable that the Qu-Pad app wouldn’t care, it just accesses the network?
How about continuous pots rather than faders or wheels? Smaller + cheaper + already used by A&H. In fact ones with a push/click too, used as the select button would be good.
I’d love the fader option really, but I think you’re right about power.
Adding that to a midi controller (a BCF2000 for instance) might be an option - if the Qu-Pad app supported it… (and assuming that the wifi limitation has been overcome).
True! And you still need to look at a display to know where you’ve turned it to (I know I can hear changes live, but I can’t set something in advance by ear). This is also the case with wheels.
And wheels take up a lot of space.
So we have to come back to motorised faders, and live with a relatively big bunch of batteries.
I don’t think the wheels have to be large, glancing at the faders for level information is, IMHO, easier than finding them and grabbing them with fingers.
Maybe a full body harness, with batteries at the back and an iPad table at the front, with a cup holder
Or just another QU16 at the back, connected over WiFi as a remote controller
I want a heads up, 3D display, showing me every function of the desk & using cameras and motion detectors to allow me to operate it all by moving my fingers.
Bellringer make one and it only cost less than 2 bags of chips.
You will tell me if I’m loosing the plot won’t you…
I’m thinking that a “wheel” that is ~1cm wide doesn’t even need to be as wide a diameter as a mouse scroll wheel, so not as much room as you might think.
For a really radical idea - have a “belt” rather than a wheel, maybe with an LED “fader” location indicator if they are full height.
Most of the feel of faders (no instant feedback of level), but without the requirement to motorise. These could reasonably be 40-60mm “belt faders”, since they would be used for adjusting the level, and you could pull, reset, pull…
So a case which fits all the current variants of the (full sized) iPad - i.e. probably uses corner clips or a sprung side
With a strap on the rear - like 10 iPad Cases With Convenient Hand Grips | Mashable
And a set of 9 faders/wheels/belts basically lined up with the iPad screen
And a couple of buttons/wheel to select which layer on the iPad (up and down buttons)
Bluetooth or 30pin&lightning connectors *
Charge Through port - If it takes power (bluetooth, leds) then a charge through connector (USB B?) to keep the iPad topped up (whilst the device has input power), if it occupies the 30 pin or lightning then it should at least be able to pass power back.
*Bluetooth is quite attractive in that it is going to be relatively future proofed against apple changing connectors again, the others give me better reliability feeling, and lower power requirement.
ios now supports MIDI over bluetooth. So as long as the Qu-pad app supports midi input control, all the bluetooth midi controller should be able to work.
