Hello,
Im very new to working with digital mixers and was wondering if it was possible to control the mixer from my iPad without it being connected vie ethernet cable.
Any suggestions to work around this would be a huge help!!
Thank you
Scott
Hello,
Thank you
Scott
You cannot directly connect via Ethernet anyway. There has to be a wifi router connected via Ethernet to the network port on the console. Then you select that router in your wifi menu of the iPad. Then you can connect to and mix running the current app to match the current firmware. If you are just getting the app then you will have to make sure your console has that version or later firmware. Apps are not backward compatible. Meaning 1.80 of the app will not work with say 1.73 or lower number firmware.
Hope that explains it.
Ahh right okay, ill give that a try today!
thanks mate
