iPad OS 14 not finding QU-Pac
I see there was one thread started about this, but I wanted to start another to see if anyone else is having issues from updating their iPad to OS 14 (I’m on 14.2 currently, iPad pro) and not being able to connect to the QU-Pad app anymore since the update. My iPad mini running OS 12 still connects fine.
I assume you can still connect to the network that the mixer is on but the QU Pad app
is just not seeing the mixer.
Is the mixer on the latest firmware or at least one of the last two?
Try deleting and then re installing the QU Pad app.
Had a client with a similar issue after an IOS update and after checking
most everything else re installing the app took care of it.
Oh man…that was easy. I’m an idiot.
Thanks for the simple reminder!!! works great now
Good to hear!
That seems to be a a random IOS update glitch, I wonder if any other apps have that same random issue.
I’ve updated my iPads up to and including 13.3 and never had an issue. I have not updated past 13.3 at this point.
For what it’s worth I only use my iPads for operating mixers and my system DSP’s
You know, this type of thing used to be so common in terms of trouble shooting, but then you get used to things always working and forget that something as simple as a restart or re-install will fix it.
