I am pretty new to the mixing world. I have had a look around but couldnt find any info in the search box.
I have an I Pad Pro connected wirelessly to a Network extender. I have matched the software with Ipad and QU24.
All connects great and works fairly well, untill the 4-5 minute mark where the Ipad then suddenly disconnects and displays disconnected and puts up an IP address.
In can then click connect to QU24 on the Ipad Pro again and all fine, then the same time scale again and disconnected.
Thank you in advance for any info regarding this query.
We dont know the ip address for the extender we just did a master reset, hooked up the IPad Pro and connected no problems at all, then after the 5 mins the ipad seemed to disconnect.
I did find that it was only when my I Pad wasnt in my hands being used it disconnected.
If you are not an expert on networking
Do it! Spend the extra money.
My iPads, once connected stay on line without glitch’s.
I use the airport extreme.
Once you purchase the Express or Extreme you should then download the app made by Apple called “Airport Utility”
It is a wonderfully simple app to use to set up your new router.
If I may suggest that you purchase an Airport Express router as opposed to the Airport Extreme. The Airport Express has the very convenient feature of being able to stream stereo music digitally from your iPad, Ipod or iPhone directly to the router.
The router has a 3.5 mm stereo connector so you can connect the audio output of the router to two channels on your mixer.
When it is time to go on break, the sound guy strolling around with the iPad does not have to frantically run up to the stage to turn on break music, he/she can do it right from the iPad, wirelessly with your custom break music in iTunes, IT’S WONDERFUL!
Why are you playing music from 3.5 into XLR? Why not the 1/4 inputs. The XLR inputs are mono. Your 3.5 is stereo. If you put both channels onto that XLR you’ll get a big cancel with the differential +- inputs.
it is very very very bad to terminate any 3.5mm stereo plug to two XLR connectors!
It is then possible to inject 48 volts phantom power into the output of your iPad based on the wiring used. This will completely fry your iPad/iPhone/iPod.
A 3.5mm male plug should never terminate to XLR connectors but instead should be terminated into two unbalanced 1/4 inch male plugs.
