IPAD tap tempo ???
Hmm, why do you think tap tempo function has been moved to Fx returns on ipad app? So bizarre.
On iLive app tap tempo was easily accessible. They were part of the FX sends, not returns. When you adjust FXs after double tapping a channel, if you wanted to dial tap tempo, all you had to do was to single tap on the Delay FX channel and tap “ch”(processing). Now, we have to scroll all the way until we get to FX returns. Is there any plan to put this function back to Sends section? Maybe to both sends and returns section to make more people happy?
Also Routing & Processing buttons need to go back to right hand side where you can easily tap with your thumb. This is where “ch” & “Mix” buttons are located in iLive ipad app. The current location doesn’t make life easy, nor ergonomic.
Thank you.
