Is there a way on MixPad software to
On The Mixpad software I am looking to switch Auxes from pre to post. Has anyone else done this and can you share the process
Granted I’m new to the SQ Mix Pad app but unlike the QU Mix Pad app I don’t think there is a way to globally change and aux/mix from pre or post using the SQ app.
You can change it on a channel by channel basis by either sliding the fader control panel all the way up to show you the on/off mix select and the pre/post button at the top of fader or with the with the channel fader window slid down it will show all the mixes and groups and their selections in the top window.
To do either of those you have to have a mix/aux selected.
in the preamp section scroll right and open the aux, dca and matrix routing page … there you can choose between pre and post fader
That is not a global select for the entire mix/aux though.
You explained better what I tried to as a second option.
