itunes and mac
Thanks to all who replied to mimmo’s OP. I couldn’t find it anywhere in the guide where it explained that STR1 came form stereo output 25&26 (Qu-24) and so on for STR2 and STR3 when USB Streaming. This is my first mixer and it can be a tad confusing.
You guys rock!
~Craig
thank you so much everybody for your replies.
I have also installed both DAW control and TCP midi driver.
Even if I actually haven’t find a solution I do a test with quicktime player and with a UVI grand piano.
Both of quicktime player and UVI grand piano works well and I can ear them coming from ST3.
But no sound coming from itunes and safari (youtube ecc. ecc.).
Thank you for your helping.
MImmo
A pics to Check if it well set.
I just upgraded to Yosemite 10.10.1 and this problem is solved…
Hi all,
We are aware of this routing issue on some versions of Mavericks and Yosemite. Looks like an OS X bug since it affects other products with different USB platforms.
There is a possible workaround which we found to work in most cases: in the Audio Midi configuration window, go to Multichannel Mode, and ensure that it is set to a valid Multichannel mode, for example 5.1, NOT stereo. Stereo audio should then return to the correct channels.
Hope this helps.
