K3. Problem with Traktor maps. They are not compatible
Hi, many of my K2 mappings for Traktor aren’t compatible with the K3. The problem arises when you configure two functions with two different colors on a single button. The issue is that Traktor’s “send monitor state” function doesn’t work on the K3, even though the same mapping works perfectly on a K2. This is a major obstacle. Is there any way to fix this?
My two cents about Traktor and K3 from another topic:
I have found out Traktor every time sends a command to disable previous note (disable LED) and enable the new note (enable another LED). But sometimes Traktor does this in a wrong order: at first it enables the new note and afterwards it disables the old note. That means - Traktor will disable the same button on K3. This is the problem only if You are trying to change the color on the same button. It works fine on a different buttons and worked fine on K2. But on K3 LED color changing on the same button is wonky at this time.
Hi One & All
Xone Controller Editor V1.0.1 is now online
V1.0.1 implements a firmware maintenance update for Xone:K3 that brings performance improvements and fixes for LED feedback issues discussed in the community that are reported, replicated and logged with A&H Support.
macOS and PC Xone Controller Editor v1.0.1 Installers are available via the Software Downloads section of the Xone:K3 Resources page
Follow details in the accompanying software release notes to update your K3 controller once the 1.0.1 Editor is installed.
Release notes includes changelog information for the fixes
Thank you for your patience
^Al
