LED rotary knobs
It would be awesome if we could assign the LED strip light, display brightness, and scribble strip LED to a rotary knob so we can easily adjust the brightness.
Or at the very least create a hot key to go to the lighting page in the console
Thank you!
@Nick
There is a shortcut to brightness from the home screen, which can be seen with processing or routing screen key pressed when no channel is currently selected.
Quickest way there from anywhere is to press processing key a few times (depends what you were looking at last) until home screen appears, then press the brightness button.
(but your suggestion for Soft Rotary control would be even quicker!)
Cheers,
