Library Manager operation improvements
In current form, Utility > Library Manager is a pretty limited way to copy Libraries between dLive and USB. It’s neighboring tab (Show Manager) is a bit more robust and user-friendly. Suggest the following improvements:
  1. Add options for “Copy All” buttons to match functionality on Show Manager.
  2. If copying a library with a name that already exists on the target, add option to overwrite, as with Show Manager.
  3. Ability to show file info on a Library (ie: date it was saved) for help with version control. Again, as with Show Manager.
Not to get greedy, but it would also be helpful to add directory/folder structures for Libraries. ie: instead of a single alphabetized list, the ability to group libraries by (for instance) vocals, drums or other categories as they may apply to the user. Then I could copy over my entire drum channel strip settings in one tap, rather than first deleting (if they exist already) on the target and then individually copying over each library.
+1 the whole library system could use a nice update.
From what I can tell, the libraries are not “universal”, but stored within a show.
The ability to recall any library from/to any show would be great.
Both the Library and Show Manager could really use some work. Folder/tag structures, write protections…even something as trivial as additional characters would help in sorting shows and Library presets. Currently, everything is just thrown into one big unsearchable pile.
You can import scenes and libraries from other shows. This is not limited to USB shows.
+1
