Link two AR2412
If it’s possible please make a firmware update for the GLD to link a second AR2412 to the first AR2412!
I own a GLD as well as a Qu-16 and for both desks i would like to have a AR2412 (and not a AB168) so for a bigger event I could link the two AR2412 zogether and use them with my GLD!
I will second that idea. No reason why 2 2412’s shouldn’t work. Or so it seems.
So are you saying using 2 AR2412’s into a GLD?
Isn’t the cat5 cable system limited to 40 channels?
Yes dhak 2 AR2412 into one GLD! (And not through the extender port onthedesk!)
Where did you read about the 40channel limitation? Network should be able to proceed more than this I guess
Good on you for thinking outside the square!
I didn’t read any info about max channels being 40.
Constructive gossip… discussion that happened somewhere.
How many channels does the ME1 handle?
ME does 40. So in that scenario it would be 24+24in. 12+12 out and 40 ME. Not sure that is possible but good food for thought.
mmm
So which is the A & H product that will fill the gap between the GLD and the new iLive or is it dLive?
should soon know. About 3 weeks.
I’m not asking for 48 input channels! The GLD CPU might be only able to process 44Channels but using a second AR2412 like the AB168 plugged into the extender slot of the main AR2412 to distribute the input slots!
YES YES YES
Now I understand what you are asking.
I asked for that 6-8 months ago with the QU series …
all this gear & equipment. but just not quite organising it around the stage how us users would like to implement the stage boxes with distribution.
Yup, I agree with you totally whether its with the GLD QU or whatever.
I’m not sure any sort of patching takes place within the ARs themselves. It would make more sense to do that back at the mixer, at a central point.
Yeah that would be great. I also have a Qu system and a GLD system and I want to avoid buying a AB168. I always use an AR2412 with the Qu and it would be nice if I could use a second AR2412 on the GLD instead of an AB168 on the extender port.
