List of suggestions
After using dLive for the past few months I have a few suggestions that I’ve come up while using it.
Some might have already been stated, but here’s my list so far.
Midi Sel
Midi Mix
Midi Softkey
Note: you would have to have a console instance and the midi note command would specify a instance for this to work properly.
Ip8 Sel
Ip8 Mix
IP8 SoF
Note: simply follow the surface that this is linked to.
Routing:
Direct out pick point per channel & buss
TalkBack mic source aux/group/mtx
IO patch libraries (like SQ)
Changing IO slot in HA abcd source keeps socket same
Softkey abcd set select specific channel(s) or a range
Scene recall filter:
Individual insert A or B
FX/Deep/processing:
Deep EQ models
De-esser & LF Dynamics for vocals
Guitar amp models in FX engine
Deep Comp models in FX engine so we can have two compressors on a channel
Replace gate with compressor/expander
8 band PEQ (or higher) on outputs (replace GEQ)
6 band PEQ on inputs (replace HPF/LPF)
Harmony UI:
Insert tapping engine takes us to that view
Rta on peq
Rta on gate/comp key filter
Post fader meters
Hold mute group button to add assignments (do this for dca too) [similar to x/m32]
Way to enable hpf when setting via rotaries (c-class) [hpf auto enables/disables when moving past 20Hz]
Clicking a meter in meters takes you to the channel processing and selects that channel and recalls a fader layer with that channel present (options in settings)
Virtual banks which are recallable from softkeys or scenes (scene recall works for this)
Show rename keyboard to have left/right arrows for moving cursor; add delete button
MixPad:
IO routing page [absurdly useful]
FX page
Copy desk layer
iPad pro
Android
(honestly I just hope that mixing station comes to dLive)
Welcome to the DLive family!
There are some great ideas in here. A lot of them are already suggested in the forums so it would be worth your time to search some of them out and add a comment/like to those posts so that the A&H teams see individual requests getting publicity rather than a long list.
I am all about the MIDI functions getting added in and the RTA on PEQ is something that a lot of us have asked for, for instance.
most of the above was requested before
Thanks, I did search. I also do go back and do the +1 for relevant threads. I also know some was already suggested.
Simply making the Dev team easily able to add desired features to TFS.
