How do you measure your LUFs or similar required levels for streaming to radio, TV, CDNs, yada yada?
Radio & TV have legal requirements to be met.
CDNs have specs that they will do what is necessary to fix your levels to fit, if needed, or in some cases reject your file.
Clearly nobody has calibrated ears that can guarantee that their signal level is proper per legal specs.
For many churches the sound is sent to a PC with OBS or similar to morph with the video and may be further processed.
We can not control what happens there so it seems best to just send them a LUFs spec signal unless they say otherwise and indicate they will readjust after their processing to meet legal requirements or others. Some send direct to radio/tv so should be at correct levels for those. And some people feed multiple destinations and need multiple differing levels to be transmitted onwards.
So if the video PC does not have visible meter then we definitely need one. I would like to have one anyway if just for the live audience that might have SPL levels restricted by local laws.
Seems like the best way is to add a PC with a parallel output from the mixer and use a software LUFs display.
Is there a simpler way a hardware device that could do it?
Or would you just give your video team something ‘reasonable’ and rely on them to fix everything.
I am surprised that the QUs do not have a better level meter with variable integration time instead of just coarse levels and leds and using a very short time that they are valid.
I want to Live stream on facebook using my Android A32 Samsung mobile phone . In my Live streaming music video I want use the Audio send thru the USB from my QU16 to the Andoid Phone A32 Samsung
But I am unable to receive audio in my Android phone
I can receive from My Yamaha MG 10XU mixer but not from Allen and Heath QU16 mixer. I have routed my Channel 1 and 2 to Master L & Master R to USB
can someone help me
Ignore the blathering in the first post that started this thread!
I never tried using the USB connection to directly send audio to a phone, I’ve
used various adapters to get analog audio into a phone though.
Are you only using the Facebook interface to broadcast the live stream?
Maybe for an experiment send the L R audio to all of the USB output tracks at the same time and see if your phone and or Facebook picks up one of them.
If it does then it’s a process of elimination to find the one that it is.
I assume your using the same proven USB adapters that worked with the Yamaha mixer.
@Valentinos
There is no phone you send can usb to.
And the problem is vaguely confused with the yamaha mixer and sort of says he sends to the yamaha not receives.
@Valentinos Please post your question in a separate new thread not try to attach it to a totally different thread topic.
So the thread gets hijacked by a total noob, and the OP is insulted to boot with a meaningless answer to both questions.
Again I would try sending the same audio mix to all USB output tracks
and see if the phone picks off the audio from one of them and then work
back from there to narrow down the one that it is.
@Valentinos
then the problem is likely in your android drivers
that is assuming you also have the sound sent correctly to the LR and have the faders up pafl set right yada yada and then to the usbout
people using pcs do not have a problem as drivers are available for those devices
Do you have any recording apps on the the phone to see if that would see
the mixer, try the voice memo recorder, both would not help your problem
but just be more of test for connectivity.
I have not looked but are there any live streaming apps available that may allow
for external input sources.
It is sounding more like a driver issue with Android.
YES I have have the sound sent correctly to the LR and have the faders up pafl set right yada yada and then to the usbout
YES I too Believe the problem is likely in your android drivers
I have no problems on QU16 to PC people using pcs do not have a problem as drivers are available for those devices
I have used on my Android a recording app OPEN CAMERA to Rec a Video with sound configured to come from USB connected to my QU16 and all USB channels assigned to LR
BUT THE SOUND FAILED which means the SOUND SEND FROM QU16 USB is received by a windows Desktop but NOT BY AN ANDROID DEVICE
YES I AGREE It is sounding more like a driver issue with Android.
I have raised a TICKET to Allen & Heath Product Support 2 days back . I will cross my fingers wait for a reply
Friends
Below is the Reply from Product support A&H
Hi Elvis,
Much of this will depend on how the Samsung uses USB audio devices.
The Qu requires ASIO/WDM drivers for use with Windows systems and uses the built in Core Audio drivers on Mac systems.
We don’t test or officially support using the Qu with an Android device for USB audio streaming, so if you can’t get the Samsung to work with the USB interface, you may need to use a separate USB audio interface for the connection to the phone, or find a way to input and analogue signal into the phone.
@MikeC Is this possible, to send it to (what Windows sees as) the QU Line input device (ie not the ASIO multi-track)? I’ve just posted a thread asking something similar
see the answer in your thread already
see what the AH response was above wrt Qu and drivers
please do not hijack threads with other questions that are not on the same problem
start another thread with another question if you need to have another thread
