Live Streaming with obs using an aux bus on qu 32
I am trying to separate the front of the house and live streaming audios, i connected a direct line from the aux 9/10 to my computer but the sound is distorted, anything that can be done to solve that or can i change the audio source that feeds the usb.
How did you connect the mix 9/10 output to the computer?
You can use the USB B output connected to the computer and the QU 32 will show up as a sound card. In the IO routing set up menu you can assign the mix 9/10 out puts to the track that OBS want to see for an input.
If the Sound is distorted then your sound chain is questionable - Check your r Mix 9/10 output Gain - if you are running the mix separately then the FOH make sure you aren’t distorting on any channels - in Addition make sure you FOH mix is not distorting - like you have too much HeadAmp Gain and your signals are going into the Red - Also how are you connecting the Outputs To the Computer? - Are you using adaptors and running them into the mic input?
