I’m curious if the Qu series allow it’s users to output the same source (i.e. FOHL) from local outputs as well as from it’s Dsnake outputs…I know you can assign different outputs to Dsnake and Local, but I’m wondering if you can utilize both.
To clarify:
I want to send a FOH L & R signal to my tops on stage via D-Snake. I also want to send a FOH L & R signal via the local output to another room, that is isolated from the main event and is in the opposite direction of the stage (otherwise I’d split the signal at the Dsnake box). I’ve used all my Matrix, group and aux sends already…so I can’t tap into those resources for this.
Any thoughts?
(PS - 1st post, sorry if this has been covered on the forums already)
Thanks for any input.
