Lockout Main mix in user settings?
When setting user permissions, is it possible to have the main mix locked out from a user? I want to give a single user account full access to a single auxiliary output (record mix) to mix from an ipad with the SQ Mix Pad app. It seems the closest i can get is to limit it down to accessing only the record mix (Aux 4) and the Main mix. But if that user is mixing from the video room, they might not realize if they are on the house mix and messing with things there.
you can use the SQ4You app it’s restricted to a single mix by default
