logic interface for virtual sound check
Hi all
i have a QU16 and logic i got it set up to so that logic can record from the desk fine but realistically i would like to route the channels back to their designated inputs to be able to do a virtual sound check and ive becom stuck on how to do this is it possible??
thanks in advance
carwyn
@hopcazz
how many channels
how are they recorded? usb qu drive other output(s)
cant do it in real time
but you should be able to play the recording back via usb or qudrive
just not send it to the original inputs
hi ive recorded it through usb b to logic and just want to direct them back to the original channels i know you can do it on the qu drive but trying to work it out on logic
thank you
carwyn
maybe you should ask this in a Logic forum?
configure logic so that it sends every recorded chanel unmixed to an output
@SteffenR
sounded like a Qu problem to me that he is asking about
I presume he knows how to play back from Logic
You need to go into the pre amp source menu and set the channel inputs to USB.
