Logic Pro X integration
I know how this is supposed to work, but here are a few problems I cannot solve. DAW Control works as it should. No problem. I can add four instances of my QU-32 in Control Surface setup. Faders act as expected with the custom layer engaged. Yet, if I close the project and reopen, I have to “re-attach” the 4 banks of 8 manually.
Another issue I don’t understand is that the QU-32 isn’t in the environment window listed as a physical input. It’s in the midi setup app on the Mac.
Details: Logic 10.4
Mac OS 10.13.3
QU-32 Firmware 1.93
Any advice would be greatly appreciated since I cannot contact tech support due to messages informing me my email address is invalid, which it isn’t.
Hi tooloud,
If you try sending an email to support@allen-heath.com we will be able to pick it up there and help you with this.
Alex
Welcome to the club, I have sthe same problem using the same configuraiton and V 1.93 firmware of the QU 32 did not solved the issue…
Each time I open a project I have to re attach the four midi banks from Logic to the QU 32
Rather boring infact
