Lost FX send bus 1
Programming up for a show and FX send 1 has vanished. It is there and still labelled in the strip assign window but is labelled not assigned in the FX window. It was assigned to a strip but dissappeared while assigning comps on input channels and I cant get it back. I can assign anything else to the same strip but cannot assign the bus anywhere. 8 sends are selected. I have rebooted and still missing.
maybe you switched the FX 1 to Insert?
Check the back panel of FX1. Almost certainly either set as an insert or unassigned.
DC
Yea cheers, I did find it. Not sure why it was unassigned as I had tested it then gone onto placing comps etc, must’ve bumped something in the I/O window
