"Lost Password" problems
I send my email to re-set the password, and the box says:
Check your e-mail for the confirmation link.
But no answer from Allen & Heath. Why?
Check your spam inbox. It may also be worth going through the lost password form again on the off chance that you mis-typed your email address.
Chris
Thanks Chris,
I did both things, but I re-tried and still no result. I put a ‘tick’ in front of,
Notify me of follow-up replies via email
when I opened the post, but I guess the wording wasn’t clear: my initial post did not generate an email. So now I will see if this post generates an email.
What I’m trying to get are three files:
Dante Firmware Update Manager for Windows (19.81 MB)
M-Dante firmware V3.7.0 (2.56 MB)
& (if Windows doesn’t work)
Dante Firmware Update Manager for Mac (18.82 MB)
Audinate Dante Controller will let me run ASIO when iDR48 is turned on and the M-Dante module is plugged in, but that’s about it. No address. Not much except the name. And yet Audinate Dante Virtual Soundcard works with the Audinate Dante VIA (I have green dots for those, and they have addresses, etc). Strange.
jabney, could this help while you sort out the password issue WeTransfer | Send Large Files Fast
RayS
Thanks RayS, Sorry for the delay getting back to you (I was hoping to get an ‘official’ answer - but it has been a week or so, so I have been trying your solution).
No result. On the good side, the ‘we’ thingamajig seems to work well. On the not-so-good side, every combination I’ve tried of DanteFirmwareUpdateManager_pc-1.3.2 and DanteFirmwareUpdateManager-1.4.5.7 have ended with,
“0x800b0101 - A required certificate is not within its validity period when verifying against the current system clock or the timestamp in the signed file.”
I’ve tried it with Bonjour and without Bonjour under Windows 7 (1), Vista, Vista (2), Vista (3): all with “Run as administrator” and all without admin.
Any ideas?
Anyhow, at least ‘we’ is cool.
edit!!!
Now I can see the green checks, and under Device Info I get: AllenHth-######, Dante Option Card - 3.6.4 - 192.168.0.1 - 1Gbps - NA - NA
At least I know the device is still working.
best, john
