Low USB output to DAW
Hey folks, next question, I’ve opened up a logic session and routed all the inputs to the appropriate slots in the DAW so we can play with a click and backing track. Tracked my guitars as a test and with the level at 0 in the CQ18t and MAIN LR at 0 i’m getting only -16db into logic… any help on how to boost the signal?
That level is correct as the digital world differs from analogue. But with using either 48 or 96khz you can raise the volume without introducing any noise.
It also prevents clipping which isn’t something desirable in the digital domain.
Hi guys, sorry to revive this topic but i’ve got the same problem. In my daw 0VU = +4dBu = -18dBfs so it has to be in line with my CQ-12T. How did you manage to solve this issue?
