LPF recall on startup
Hi there
Running LR+SUB setup on IDR48 and T80 combo. Firmware is 1.70 on all devices. I’ve applied HPF on LR@100Hz, and LPF on SUB@100Hz. These settings are saved into a scene and a show, and when we recall from either of these everything’s fine.
When we start up our IDR48 “from cold”, it recalls the settings last used, except: The SUB LPF is recalled to 2KHz. We can reset by hand (the 20-20K setting is recalleD), or by recalling either the scene or the show, but we’d still rather it worked properly right away on startup.
Any chance someone else can recreate this issue, and perhaps work on a fix?
“A computer once beat me at chess. It was no match for me at kickboxing.”
-unknown.
Woohoo!
Thanks for the update, much appreciated!
-unknown.
Hi Chris
This is a known issue and will be fixed for the next version of firmware.
Regards
Sam A&H
