Hi
Can i add a limiter in my master (LR) channel (Qu16), in order output do not exceed 0 db?
The reason is that i have powered speakers and i want protection.
Hi
Turn on the compressor on the main out and set ratio high. Adjust threshold for peaks.
Thank you GCumbee
I suppose ratio goes to infinity? And the threshold top is 0 db?
Yes. Set to INF. Normally limiting is way up like 20:1 but they only go to 10:1.
I would set the drop down to MANUAL PEAK.
Set the threshold to where you are getting some reduction on loudest peaks or the music or vocals. Just hitting the tops. But will reduce more if there is a sudden burst of something. Hopefully.
