m-dante for second mix
Hello, I have ilive r72, iDR 32 and m-dante. I’ll use the dante card to make a second mix for broadcast. I have also PC, Pro Tolls and m-audio profire 2626 sound card.
My question is, will I be able to make my mix on my computer,make multitrack recording and send back to ilive the mixed signal. And at the same time listen to the signal on my Yamaha ns10 monitors through the m-audio card or I will have to run the cable from the aux out on iDR to my monitors?
As long as your computer is able to do mixing and recording at once I don’t see any trouble. Keep in mind quite a big latency, but for the broadcast it doesn’t matter. For the M-audio card you’ll have to use Dante VIA to route signal.
ddff
