Hi, I’m prepared to pull the trigger on an M-Dante for my iDR-32 and I have a few questions. Please forgive, some may be basic questions.
With Dante in my iDR-32, will I be able to route all 32 input sockets to my DVS host as individual recorded tracks while simultaneously mixing down to mains and auxes in a traditional manner?
Will the routing to Dante be pre or post gain/EQ/dynamics/fader? I would like it to be post-gain.
Later, can I play back all 32 recorded tracks through the iDR-32 and mix them down to mains and auxes using all of the processing and DFX?
Finally, is $1,600 the price of admission in the states or can I do better – if so, where?
Thank you!
1: Yes works fine on my IDR32 every time.
2: You can choose Post preamp gain, Post HPF, Post Gate, Post Insert return, Post PEQ, Post Comp, Post Limiter and Post delay. Also Follow fader and follow mute. Don’t think I have ever heard of a pre gain direct out though.
3: Yes, either on the same channels you recorded through or the 32 reamianing channels of the IDR’s 64.
4:Pretty much the same everywhere unless you find a used one or campaign.
IDR32
Dante card
Macbook pro 17
Ipad2 + mixpad
Aiport express
If you chose “MixRack Input” instead of IP direct out then the feed to the Dante will be post gain but pre-trim. If you take Direct Out its post gain and trim.
To do this you’ll want to set up a couple of scenes that just change the input patchbay. What I usually do is make scene 1 a full scene with all parameters. Then scene 2 and 3 are scenes that only contain the patchbay. On scene 2 update it with all the IP sources coming from the Mixrack sockets and on scene 2 update it with all the IP sources set as Dante inputs. Then recall scene 2 to mix a live show and recall scene 3 to playback and mix a recorded show. Changes to EQ or FX or routing (etc etc) that you want to make can be saved in scene 1.
You might trim a few dollars off that price if you find one used, but they are a rare commodity on the used market.
-d
David Shriver
Director of Technical Operations
Email: david@rockportmusic.org
Shalin Liu Performance Center
37 Main Street
Rockport, MA 01966
