Hello, I have a T112 with an IDR48 fitted with an M-MMO Card in the port b slot of the IDR. I’m trying to get the M-MMO Card setup up to feed an Aviom system but can’t figure out the routing in the outputs screen. The card is showing up but I can’t figure out how to feed the card direct outs and a couple of aux sends. Thanks
Are you at the Mixrack setup screen. There is a tab for the MMO output card(select it).
On the MMO routing screen you have to select the Aviom port. Once that is selected, for each channel you have to select the “output source” be it a Input-Direct out for an input channel, or an aux send, a matrix, mains, etc… then the specific channel of the source.
Make sure to “apply” the changes or they won’t take effect.
Got it. Thanks
I wasn’t totally correct, from the “outputs” screen is the tab for the port-B option card where you will assign the outputs.
Sent from my SCH-R970 using Tapatalk
