MADI Inputs in Editor
I’m sure this is a simple question, I have my laptop connected running the editor and Sonar (via MADI) and would like to switch the MixRack to use the MADI inputs rather than XLR - where is the menu option to do this?
thanks.
quote:
thanks.
After more toying around, I see you can change the inputs individually in the preamp section to a MADI input, which works fine. However, this can be tedious to do for each track. Is there a shortcut that just switches all inputs to MADI and back?
The virtual soundcheck video implies there is an option that just “switches” the inputs however he is using a surface to do it and doesn’t give details as to where he is on the surface. Can the editor do this? If so where is that menu option?
just a quess- hot keys involved?
ddff
thanks.
you need the surface…in the mixrack/setup/mixer prefs page …
I’m doing a similar thing with m-MMO and I made 2 scenes that switch only the physical patch and the pre amp/trim levels (essentially from mic to line) all other parameters are untouched…so you only do it once without affecting your
RayS
R-72/iDR32/iPS10
quote:
thanks.
RayS
R-72/iDR32/iPS10
Really? So you can’t do it from the editor? Wow, that kinda sucks… I am only doing this for 16 tracks but still, seems like such a simple feature to implement…
+1 for the “switch global input” feature in the editor.
Wouter
My prayers have been heard, Dante is coming!
