Hello Everybody!
What is the best way to route and connect an effect to the master bus? I’d like to put an Elektron Analog Heat in my main master
Stefan
Hello Everybody!
Stefan
you mean you want to use an external device to provide some fx ?
the best way would be an analog board with a jack for insert return.
digital is best to insert fx from a library inline inside the Qu.
dont know if AH has a distortion that you could insert from the library.
Else On the Qu you would have to run the signal out from available choices,
then process it with the fx box, and finally return it back in via available inputs and finally send it to the LR bus.
