Does anyone know why the main LR will sound different when you have the PEQ and GEQ on or off? I created a brand new scene and I haven’t touched the PEQ or GEQ for the main LR so they are still flat with no EQ done. I noticed that engaging or disengaging both EQ processors affected the sound, making it sound either more low end heavy or not.
Strange and totally opposite to my experience. I’ve tested that several times and no change in tone. The only reason (for me) to switch off eq’s at all is to maybe save some on internal computing power.
Giga
@David
It sounds like you think that saving a new scene will reset your EQs, but that is not the case.
Therefore, save your show and do a reset as described on page 83 of your manual.
After that, you should see/hear that there is no change when you disable flat EQs.
However, this should not have any effect, because your console is designed in such a way that the required computing power is always available for all processing components.
