I finally got my new SQ5 and feel like a 5 year old at Christmas. I have most everything setup and going except one thing that I want to do but I am not sure now if it can be done or not. I have an overhead speaker on its on Matrix that uses Main LR as its input in my sound room that I am using to monitor the FOH for our services. I would like to send the PAFL to his as well so that I don’t have multiple speakers and not have to use headphones.
Is there a way to send the PAFL to this speaker as well? I know it can be routed uses MIX Out in the IO Screen but then that cancels out the regular feed that I have setup.
PAFL will override the main L R audio just like when using headphones.
In the PAFL set up menu check that LR to PAFL is selected.
That way when nothing is PAFL’d the main L R mix will be heard.
Pick any unused output to assign to PAFL, don’t forget the A & B 1/4inch outs.
Thanks Mike. If I’m understanding and set everything up as described, I will have the PAFL on all the time even when listening to the general Main Mix. Correct?
